1 - 20 of 29 Posts
So I am a little confused.
found this list of parts online for the rebuild of cm450 front forks.
mine feel a little squishy.
so which do I really need ?
or do I need it all ?
51412-369-000 SPRING, FR.
51437-413-003 RING, PISTON
90601-369-000 RING, OIL SEAL STOP
91254-413-881 DUST SEAL, FR. FORK
91255-413-881 OIL SEAL (33X46X11)
94608-30000 O-RING (23X2.4)
Ring, oil seal stop depends on the condition of yours. If it's good no need to replace, rusted/corroded=replace
As for the rest of it I'd use all of those. Fork seals and dust seals are available from All Balls Racing. Also you will want to check the spring lengths against the specs in the FSM. Use 10W fork oil instead of the ATF spec or Honda's 7-8W fork oil for a slightly stiffer front shock action
That's the worst I've heard of so far but not terribly surprised. 10W fork oil seems to be the best choice, a tad stiffer than stock at 7-8W. 15W is about as stiff as you will ever want
I was going to get the honda fork oil. the dealership down the street has it.
Bought the all balls set. for seals.
Well. I got one of them apart.
The other. The 14mm bolt on top rounded off under the impact.
Options here ?
Aprox cost to go to bobs and pull another used one.
Or drill it out. With a die grinder ?
Yeah, even if you successfully grind it out you have to find a replacement nut. I think I'd look for another one first.
No, not broken. the slit is there to allow the 'ring' to expand.
Went to bobs. The only set they have that are alike to mine are heavy rust on top...
Trying to find that bolt online. Any ideas on who might have it
Discussion Starter · #18 ·
1 - 20 of 29 Posts
