Head gasket is leaking and the leak is accelerating to the point where I can't ignore it any more. Maybe the gasket between the cylinder and the crankcase, too. I want to replace those, and I figure if I start pulling gaskets off I gotta put all new ones in when I put it back together. I do have a shop manual and have read it over. I've done my own work on this bike and my car, but this would be the most advanced thing.
I was thinking of getting something like this:
Engine Rebuild Kit - Honda CB/CM400 - 1978-1981
I'm wondering if I'll need anything else? If I don't have to replace the gasket under the cylinder, would I have to pull the pistons? If I pull the pistons should I replace the rings? Compression is good now. Anything else I should do while I've got the engine out? It's got 40k miles (1980), my bike for 8 years, and no problems other than the oil leak right now. Actually: there's a leak from the carburetor cross-over tube, so I'm going to fix that too while I've got it apart.
Any other advice before I start? I'm planning to take lots of pictures as I go, keep parts organized in labelled baggies, and have the shop manual open on the bench.
Thanks!
Thanks!
