1 - 1 of 1 Posts
I'm replacing the fork seals and at the bottom of the fork where the bolt goes in there is a thin rubber seal that I can't find on csml:
https://images.cmsnl.com/img/partsl...-fender-cm400ta-79-80_bighu0131f7z08_a315.gif
Update: it's very old locking agent that has become just like rubber. Remove and apply new, I cleaned the tube with break cleaner.
It was in the small hole you see below right where the bolt goes it. It came out when I pressed paper through that little hole to clean it.
1 - 1 of 1 Posts
