A second attempt at for this post, the last got well and truly Fubared (but me) posting wrong info.
Any how a quick recap, basically my engine is down on compression, 125psi when it should be 180psi.
Looked at stripping it before but cam to a halt as two of the eight head bolts would not come undone due to corrosion The two that were corroded were the inner two on the r/h pot.
Decided to drill the heads of as a hacksaw and grinding was a no no for obvious reasons. So engine out top cover off and ready to go.
I used an old bolt with a 14mm hex head, and cut the head off, faced up in a lathe and 4mm hole drilled in the centre. Put my 'jig' in a socket then over the head bolt. First covered the exposed rockers and cam with an old towel with a hole cut in it. I also have a huge magnet with a hole in, wrapped this in a plastic bag and placed over the head bolt. Drilled through my "Jig" with a 4mm drill to just over the thickness of the head bolt, the opened up to 7mm then a 10mm. Put a 14mm socked on the head bolt and it just popped off. Head cam off fairley easy but now the barrels are proving troublesome t move. Will apply a little heat tomorrow and hopefully get them off.
Pictures below.
Pictures below.
