Howdy there fellas. I have a 1979 CM185 that I accidentally nuked the other day. The extent of my electrical knowledge has been dealing with a trio of 1964 C200s that were dead simple and $30 of gack let me swap them over to 12v. I tried the same thing on the CM here and she died immediately when hitting the start button.
12v head & tail, signal bulbs
12v universal rectifier intended for a C90 (plugged right in and crossed my fingers)
LED flasher relay
12v battery
On my older bikes, this is all I had to do; no condenser or ignition coil changes necessary. Here, though, I turned the key and all lights came on, but the start button killed everything - fuse is intact - and now key on/off does nothing, no spark, etc. my question is, I guess, what did I blow up? I'm a dunce with the voltmeter so I was hoping someone that knows the wiring on these things might direct me to what component I've gone and ruined, if not all of them. I wasn't expecting everything to die all at once like this.
LED flasher relay
12v battery
