having issues with my clutch on my 73 cl450 it seems like it is pulled when i go to kick start it and looking at it it isnt pulled at all. any help on how i adjust this so that the line is looser then the actual case? or does/did anyone else have this problem???
heres what i put up on motorcycle journal and they were not very helpful
on my honda cl450 my clutch cable seems to be engaging the clutch so that when i kick start it, it will only grab when you go slow which inturn will not start the engine, if you kick hard it will blow out your knee, is there a special way of setting this??? or can anyone point me in the right direction?? bike is in neutral i just got a new wiring harnes for it and all new lights, so i have the light on and the bike is in neutral, but with out touching the clutch is where im kicking and nothing happens, so it is way wacked out, i havent touched it and i had it running the other day with no issues, im not sure why it started now. the kickstart moves freely without the clutch lever pulled. i screwed both adjustments all the way in and out and the kickstart is still moving freely
Thanks
Thanks
