Hello, I have a SL350 k1, when I have finished with the bike, I come back a couple of days later to go for a ride, the clutch plates are stuck together. Too get going I roll it down a slope with the engine running and kick it int first or second without the clutch, after a minute or two it frees itself up and off we go no problem. I use good quality 15/40 mineral oil. I have another twin that doesn’t have this problem, can anyone offer some advice? Thanks Lionel
Check your oil for fuel smell, IF so change it.....Fuel thinned oil "dries" very quickly....
Petcock (fuel tap) MUST be off EVERY time engine is off......
Ok, thanks for this, I always turn the fuel off, but early days after the rebuild it was running on one cylinder and definitely got fuel in the oil, but pretty sure I changed it since. However I’ll change the oil again and see how it goes. thanks
Treat it like a British bike...if it happens to sit for a day or so, clutch in, give it a kick, then tickle carb, one more kick to prime, then ignition on and give a mighty kick.
I fixed the sticking clutch on My Goldwing by switching to a different motor oil.
