Hi all,
Having dramas with my CB360 clutch not disengaging when the bike is warmed up.
It's fine when cold, but as it warms up it slowly gets more and more play in the lever until finally the lever hits the bar before the clutch is fully disengaged.
If I try and take this slack up while the bike is warm, either at the side cover adjuster or lever, I get the dreaded 'pop' and have to remove the side cover and reset.
I have adjusted the clutch plenty of times successfully both cold and hot before, but now I can't find a happy medium - if I adjust it when the bike is warm, it will either 'pop' or slip when the bike is cold, if I adjust when it's cold it won't disengage completely when the bike is warm and makes finding gears and neutral very difficult.
I know there should will always be a little variance between engine being hot and cold, but this is significant, to the point there's an extra 20-30mm of play at the lever once the bike warms up.
I have completely rebuilt the bike, including the clutch which has been given new EBC fiber plates and springs. Also, checked all metal plates for warpage and basket 'fingers' for ridges, all are perfect.
Specific details are:
- Brand New EBC Fiber Plates
- OEM Metal Plates
- Brand New Heavy Duty EBC Clutch Springs (slightly longer)
- New Motion Pro Cable
- GP style lever (there is slightly less travel in this lever than the stock one before it hits the bars, but not a huge amount)
- Renthal Ultra Low Rise Bars (so there is a little more length in cable than required, due to bars being much lower than original)
- Running Motul 10w40 Semi Synthetic
- Just completed 378 big bore conversion with Suzi 850 pistons
Any ideas? Bike is running like a dream, just this one thing letting it down.
Cheers and thanks in advance for your help/advice!
- OEM Metal Plates
