If you're reading this then you've discovered what the rest of us know. Nobody makes one, so you have 2 choices for removing and reinstalling the clutch hub nut. 1) use a punch to drive it off and on or 2) make a socket.
Using a punch to take it off is ok but putting it on tight enough is improbable. Under the nut there is a concave washer [attachment=7:1fyhrcym]201_4458.JPG[/attachment:1fyhrcym]that functions as a lock washer, marked on one side as "outside", that's directional. [attachment=6:1fyhrcym]201_4457.JPG[/attachment:1fyhrcym]
Stuff needed:
15/16" 12 point socket
Dremel tool/motor
Dremel cutoff blade(Dremel Part #EZ406) and grinding drum
10" mill file
the bloody nut
Note: you'll want to file off any distortions on the nut from using the punch before trying to fit the nut to the socket
[attachment=2:1fyhrcym]201_4455.JPG[/attachment:1fyhrcym]
Starting with the socket[attachment=5:1fyhrcym]201_4441.JPG[/attachment:1fyhrcym] Wrap it in tape to make cut marks on[attachment=4:1fyhrcym]201_4445.JPG[/attachment:1fyhrcym] The tabs line up with 4 of the 12 inner points and you'll be cutting out 8 of those or 2 between each tab. The depth of the tabs is 7mm and the width is 5mm. [attachment=3:1fyhrcym]201_4449.JPG[/attachment:1fyhrcym]Using the Dremel tool and cutoff blade cut down to make the tabs, then across between the tabs. Depending on the size of the cutoff wheel you may not be able to cut that out completely without cutting into the tabs which you don't want to do since they'll be weak. Cut as much as you can and break the section out. Now that the larger section is out grind the inner section of the socket tabs for clearance on the nut[attachment=1:1fyhrcym]201_4450.JPG[/attachment:1fyhrcym] Now with the mill file narrow the tabs to get them all to fit the nut and so the nut drops into the socket[attachment=0:1fyhrcym]201_4453.JPG[/attachment:1fyhrcym] Now remove the tape and you're done
This took less than an hour to make and now I know I'll have the nut tight and right.
Or you can buy one here for $41.66 instead of a $5 socket and some time spent
http://www.hondapartsnow.com/genuine/ho ... 20203.html
