I just rebuilt my CB350 and everything seems fine except. When the bike is in gear and I pull in the clutch the rear wheel dosen’t spin Freely. I can put it in gear pull in the clutch and I can move the rear wheel but not smoothly and it isn’t free wheeling? Any thoughts? Not sure I should ride it?
As long as the clutch parts are assembled correctly, it should be fine. Wet clutches have drag on the friction plates when disengaged and they all present resistance when trying to turn the rear wheel with it in gear and the clutch pulled in. The test will be when you click it into first when the engine is running.
