I recently replaced my clutch cable with a cable from Common Motor. Most of the install was very easy except for adjusting it..... I removed the case cover, cleaned and regreased the mechanism inside and hooked up the cable. I followed the instructions from my Clymer manuel. I rode it about 60 miles and on my way home, upon pulling the lever in 100%, it would pop and disengage around 85%, if that makes sense. The cable resets if I manually close the lever you can hear it rengage. Ive tried adjusting it here and there but the problem persists. Any suggestions? I took a video but cannot seem to get it to upload here.
