trying to figure out why my clutch arm has such a huge amount of play before the lifter engages the bearing. i just replaced my clutch plates and springs with kg clutch factory KG088-7 plates and KGS-017 springs because it was slipping but the free play is still just as bad as before. steel plates are all 2mm.
the arm has ~24.7° of play and can move ~18.2mm measured from the holder on the arm to the holder on the case. the lifter is 23.5mm long and looks to have minimal wear but i cant find a spec for it. any ideas?
