1978 Honda CB400A Hawk Hondamatic
Just bought a 1978 CB400A Hawk Hondamatic as a winter project. It sat since 1982. The brake fluid has turned to a sticky dust in the master cylinder. Do I use water or a solvent or what to remove the crystals? Is the master cylinder salvageable when it gets this bad?
You can try soaking it in hot soapy water. Unless you are doing a 100% correct restoration I would skip trying to clean it and simply replace. Much more cost effective in both dollars and time with the bonus of reliability.
Thanks for the sound advice.
I've had good success cleaning this mess up with, drumroll please....
Warm brake fluid and an old toothbrush, wear gloves.
