1 - 2 of 2 Posts
Doing a resto and the you have found the other cables out there just aren't like the old ones you took off? Replacing just one cable and that universal fit throttle cable off ebay just doesn't work right?
The cables in stock at Scrambler Cycle are reproductions of originals. In most cases original cables were used as patterns. They are not 100% exactly the same but many would be hard pressed to tell the difference unless they had an original there to compare to.
Many satisfied customers with these cables.
Search Results For "honda cable" | Scrambler Cycle
Wire Cable Metal Silver Fashion accessory
Have to look into these cables, when the time comes and not have to try to get some off of ebay or whatever. This is a Lot better source and no doubt about the Source.
1 - 2 of 2 Posts
