Our 1967 CL77 has an odd custom exhaust that splits left and right tracing about the route of the original exhaust EXCEPT that it does so on both sides. I'll try to ost a pic or 2 of what we currently have. We're interested in getting it back to a more stock configureation and see that CL350 pipes look the same as CL77 ones. Does anyone know if they are interchangeable? Is there a parts interchange manual available? The custom set is thermally wrapped and has heat shields, looks like a commercial job not a backyard effort but we'd like to go back to stock or stock "aftermarket" that follows the same routing as original exhaust pipes.
Thanks
BB
If you google the part number you will be able to identify which models use the specific parts you are looking for. Some parts fiches also provide that capability though there is less support for older bikes.
Folks here can sometimes advise as to what other parts will fit with "reasonable modification" or where aftermarket parts might be found.
