1 - 2 of 2 Posts
Left pipe burns you immediately right pipe is hot but not as hot. Both spark plugs look carbon rich. I have adjusted points valve clearances cam chain. Rebuilt cleaned and bench synced the carbs. It is definitely running on both cylinders but just not as much on the right side? Carb sync issues?
Bench sync will get it running well enough for you to do a proper vacuum sync ;)
1 - 2 of 2 Posts
