1 - 2 of 2 Posts
I swapped the bars on the bike and the right side switch housing is busted. Does anyone have one? Or does antone know if there is a single cable throttle that I can swap out???
You can choose to run just the "pull" cable, omitting the "push" one.....However, as the push-pull feature is a safety issue, I can't/won't recommend it...(even though I have done it on my own personal bikes, I never do it for a customer)...... You can however use a CB switch unit, and just add a separate lever and perch... The CL ones with the self-contained brake-lever perch are getting scarcer......
1 - 2 of 2 Posts
