1 - 1 of 1 Posts
Hello.
I just purchased a set of Dime City Cycles 11-3/8" shocks to help lower the rear end of the bike. However, the steel bushing the new shocks came with does not fit, and the largest rubber bushings that the shocks came with just barely want to slide on the frame bolts. I forced one on, but it damaged the rubber on the inside, sadly. Should I look for larger rubber bushings that, or maybe just get OEM bushings and fit those in the new shocks? I didn't feel like it was a good idea to run the new bushings as they were a helluva fight to fit. Anyone have experience putting on different shocks offer some advice on fitment?
Thanks,
EDIT - I just realized this is the wrong place to have posted this as per engine size. Delete if need be, thanks.
1 - 1 of 1 Posts
