Hi everyone - My CL350 came with the brake pedal off and I need help figuring out how it goes back on. I'm thinking the pedal gets bolted on (with a washer) through the upper hole in this photo, correct?
https://photos.app.goo.gl/VXt6PFkLM5QFitV16
Does the brake pedal collar go on through the other side? Is it threaded or is there a nut holding the pedal assembly in?
Is there a trick to installing it with the rear brake rod attached to the pedal or does that need to come off first?
Sorry for the dumb questions, but I'm finding it hard to tell from the fiche. Thanks.
