I have a 1973 Honda CL 350 that i bought a couple of months ago in about 3 different boxes that hadn't run in about 10 years. Long story short after changing out the Ignitions, condenser, air filters, cables, replacing the points, setting the cam shaft and timing, changing the oil and cleaning out the goofy non-filter centrifuge i got the bike to start up and run pretty decent.
This leads me to a couple of areas where I am stuck and could use some help.
First, both carbs leak gas out of the vent lines at a really good clip. Carbs were cleaned and rebuilt with a carb kit from Common Motor. Any ideas on why they are leaking so bad?
Second, I have 3 of the 4 valves adjusted perfect but can't not get the left front (Exhaust) to cooperate. It is way tight and I have not found a way to loosen it yet. Any ideas?
Last, and I think this may be a result of the second problem is the bike is appearing to run really hot. Any ideas?
I have read a ton of posts and this forum has been really helpful in getting this old bike running again so thank you all in advance.
