Hello,
Ok maybe I was suppose to post here. 1971 cl350 the kick start spring perch broke off so I am intending to run electric start only. With the clutch cover off I can move the shaft freely in and out about 3/16 of an inch, doesn’t feel like there is any internal spring pressure. So what if anything can be removed from the engine if I’m not using the kick start and should I go in and check it out?
