1 - 1 of 1 Posts
Can someone explain what's going on here? Or, more importantly, what should be happening here?
It's similar to the other mounting bolts on the muffler, but it's obviously been drilled out, and not well. And it spins loosely in the mount on the muffler. I can see that it's supposed to slide through the triangular plate and through the tube that attaches to the frame. But I can't figure out what is supposed to happen from there. Unless I use a few washers, it won't torque down on the tube. It's long enough to fit through both the plate and the tube with a couple of mm's to spare.
1 - 1 of 1 Posts
