Hey guys! So I followed every single step on different threads on adjusting the clutch and I was able to fix my popping issue, but I have a problem because the clutch doesn't ever disengage. I can put it into first and neutral without any lever engagement. I tested it by pulling in the clutch lever while in first gear but wheel never spins freely (all while the bike is off and on the stand).
I don't know if it could be a factor, but I did replace the cable for a motion pro cause the stock one was well... stock, 40 year old cable needed replacing. I did have to shorten it because i put Biltwell tracker bars and pretty certain i did that correctly, but who knows if that could be the culprit. Thanks for any help!
