I just got home from a 4 day, 2800 mile trip to the east coast and this carb problem that surfaced the day I left has bothered me the whole way. I got home and started the bike and, sure enough, it didn't go away while I was gone.
The bike starts much easily than it did before I took the carbs apart but the the idle just runs away to about 3500 rpm or so. I backed the idle screws all the way out and I can push down on the idle screws with my fingers and it will slow down to about 500 rpm but when I release the pressure it races back up.
When I disassembled the carbs I took the choke plate as well as the throttle plates out and removed the shafts. When they were going back together, it took some manipulating to get them back in there. Could I have not aligned the throttle butterfly plate up correctly? Maybe it's hanging up a little?
It's a pain to remove the carbs on the CL (have to move the exhaust out of the way) but I'll be doing that tomorrow. I just wanted to pop the question here first to get some thoughts.
Mike
Mike
