1 - 2 of 2 Posts
I received my new rings tonight and the oil ring is 3 pieces. The first and second rings are fine I just dont know how to install the 3 piece oil ring.
Any one have installed these that can offer guidance I would appreciate the help.
The manual probably says something about the orientation of the the rings to each other but, if not, just them 0 deg 120 deg and 270 deg and that should work fine.
Install the middle oil control ring first then the bottom scraper ring so it fits in the same groove but under the oil control ring and then the top scraper ring, again in the same grove but on top of the oil control ring.
That's all there is to it.........I think. :)
1 - 2 of 2 Posts
