The tank on my cl200 is shot. I have looked online for replacement tanks and can not find anything. Can a cb200, cl175 or other model tanks fit on my cl200 without major modifications? Thanks in advance for your replies.
I think pretty much any of the CB and CL175 tanks (K3 to K7), also the CB200 tank, will fit your frame.
The issue will be finding a seat that matches. For example (from recent experience) the CB175K6/K7 tank is longer than the CL175K7 tank, and requires the matching shorter CB seat. With the side hinged seat, either of those CL/CB combos will fit your CL200, as would a CB200 tank and seat.
The earlier K3-K5 bikes have a seat hinged at the rear, which won't (easily) fit your frame, although the matching tanks will drop straight on, and might be OK with your CL200 seat.
Some mismatched examples:
CL175K7 tank on a CB175K4
CL175K7, with a CB175K6 seat
CB175K4, original seat and tank
Thanks for the reply. I think i have read where a CB200 tank will fit the tank latch has to be turned around.
