Hello, all. Having a difficult time tracking this down for my 1970 CL175 K4. Part number is 28250-235-000. Any leads would be appreciated. Thanks in advance.
I had the same problem with my sloper engine rebuild. Keep checking on Ebay. I believe that all the 175 twins use the same part but may be wrong- try cross referencing through the various parts fiches. I ended up buying a CD 175 locally that appeared to have a good one (the splines looked real nice- mine were totally buggered) but when I opened up the bottom end it was filled with a mix of water and oil and lots of corrosion. The internal portion of the shaft was badly corroded but it cleaned up okay with a blast of glass beads and works real good now. I used locktite on the kick lever pinch bolt too but will be checking it occasionally.
I have a new kick start shaft assembly for the CB 200 also fits the CD/CB 175 models.
Part no 28250235000
£125 in total. All new item , not used rubbish.
Contact email. [email protected]
Once gone it’s gone.
Also New CB200 Rear Hub for sale.
Laurence
