Hi Twinners, got a question here for you guys running on a bike without a kill switch. Forgive me if I'm missing something here: I wanted to check the color of the plugs in conditions other than at idle. I have read to go for a ride and kill the motor at whatever throttle setting you want to check, coast to a stop with the clutch pulled in, and then pull the plugs. But I have no right hand kill switch so my only option would be to turn the key off in the ignition correct? Kind of hard to do that with the right hand and the left hand is operating the clutch so....
I'm guessing the only option is to install a temporary kill switch for the right hand? Who's bright idea was it at Honda to put the ignition switch on the left side under the fuel tank?
Thanks
Thanks
