1 - 2 of 2 Posts
Does the case have to be split to change a countershaft seal in a CL/CB350 engine?
My CL350 still has one oil leak left, the countershaft seal is bad.
I can't really tell from the image in the micro fiche.
Ray, I really can't remember, although I'm fairly certain it can.......If it has "flat" sides, there is no reason it can't be installed without splitting the cases.....However, if it has the raised center ridge it can't...... Look at a new seal, it should then be obvious......
1 - 2 of 2 Posts
