1 - 2 of 2 Posts
They are usually identical internally.....There have been times Honda has used different trans ratios, but other than that..... The ONLY glaring difference I can think of would be in the SL 350.....The CB and CL have larger intake ports and take CV carbs....The SL has smaller ports and uses slide-piston carbs (some models missing an electric starter..)
Any of the three is a bolt-in as a complete unit, Most internals interchange regardless
1 - 2 of 2 Posts
