I can't for the life of me wrap my head around what to do to remove the forks. I've seen member Saturday's Wrench video when he took his off but the CB 350 has those two nuts at the top that the CL 350 does not. I may just have a few pieces that are really stuck in there and don't won't to budge even though they should be, but I wanted to ask for help before I fudged up another nuts like I did to my oil drain valve
And how do you folks suggest removing the center stand? Is it possible to not have to remove the spring, or if it is not, how do you get that spring off? Can I do it without buying the tool?
Also, is it possible to get that really stained rust off of the inside of the fender? It doesn't want to budge either.
Thanks!
Thanks!
