Can anyone recommend a (safe) method to remove chrome for instance from fenders?
I just need to prepare it for the paint job. The chrome is in really bad condition and I want a real smooth surface.Do you need to remove it, or just rough it up for paint?
TOOLS
Thanks! I will probably do that rather than take the fenders to the shop. Sounds like a good process.Just sand it with sand paper and then use self etching primer then sand again to smooth it out. Then go over it with a filler primer and then wet sand it til smooth and take care of any remaining imperfections.
This is the process I did with mine this past winter except I used an two part epoxy primer instead of self etching. Finish came out great just need to see how it holds up now.Just sand it with sand paper and then use self etching primer then sand again to smooth it out. Then go over it with a filler primer and then wet sand it til smooth and take care of any remaining imperfections.
Thanks, but I'm trying to avoid as much external shop work as possible. I will pobably try the self etching primer before spray painting it silver. When thank and side covers are ready I'll apply a 2 comp. finish on all the parts.If your going to powder coat instead of paint clean the parts with alcohol instead of acetone. Acetone leaves a film that powder coat doesnt like to well.
Just a thought.
Bill
It didn't do anything to the chrome except clean it, the underside of the fender also came clean quickly without much effort.Last night I found a different 'the works' toilet cleaner, this one contains hydrogen chloride, I also bought a pair of gloves. I'll post back after trying it.
