Hi, first time writing here :)
Have anybody had this kind of issue?
I just assembled new float set to my Honda CB450 -73 (and changed engine oil). Everything seemed to work just fine.
On the second trip (actually the very first hard acceleration) this happened: I filled up the gas tank and everything was normal when I started her up. About two minutes from filling up I drove to motorway with quite hard acceleration. Suddenly engine stopped without any warning. I don't mean it seized but went off like no fuel is burning inside, no sparkle or something like that. Speed was about 100 km/h. My wife had just said after last repair "soon it will be broke again" and when I called from the motorway she was like "I said so!".
After couple of minutes wire and head shaking I found the problem: The choke lever went on by itself! So the air flow to engine was stopped and it went off. I am 100% positive about this because I have just started without choke on (she doesn't start up with choke with warm engine).
Is this normal? Did my leg somehow moved the lever? I really don't remember any kind of weird leg movements during the acceleration.
- Osku
It's not normal but It can happen.
If you did a recent rebuild on the carbs you may have disturbed the Catch on the choke.
I'm not sure about the carbs on the 450's but on the 350's there is a small spring like tab that catches in a notch on the Choke lever and holds it in position both ON & OFF.
I would look for sometihng like that on your carbs.
This is what it looks like on the 722a carbs the 350's use.
Hmm... I didn't even look at the lever afterwards because I was in hurry. I'll check it today.
Actually I didn't rebuild whole carburettor but I did assemble the choke lever plate that connects two carbs together... Maybe something went wrong.
It has happened before for me as well, which resulted in the bike suddenly running extremely rich and bogging down to a coast. I performed the same fix as Bill mentioned and the problem went away.
