Hi, my CD200 has been hacked around and the four way plug exiting the generator area has been cut off. I know which is the points wire and also which is the neutral switch, which then leaves two yellow wires to go to the reg/rectifier.
On Ebay the units sold as suitable for the 6V CD/CM200 have the standard Honda plug connection of pink, yellow, green,red and black, and this presumably translates to two wires in from the stator, two wires out for the 6V DC, and one earth/ground wire (black maybe?)
Anyone know which colour is for which application?
Thanks!
Banned
If it's any help, I fitted a similar unit to my ( 12v negative ground/earth ) CB175.
My unit doesn't have the black wire, so I'm not certain if that is simply another earth connection or something more sophisticated.
Wire Electronics Electronic component Electrical wiring Cable
On my bike, the pink and yellow wires attach to the stator wires ( yellow and white combined, pink on its own ), red wire to positive side of battery, green wire to ground / negative side of battery.
