Hi ..Does anyone know if a CB160 or later CD175K3 crankshaft will fit the earlier CD175A sloper model please?
I don't know much about the cd175 but the only difference I was able to find between cb160 and cb175 cranks is that the primary gears and oil rotor have different slot styles, so you have to buy a crank + matching primary gears and oil filter rotor (if yours isn't the same type already). This worked for me in a cb160 using what must have been a cb175 crank (bike came with it). Pretty sure they're otherwise identical from the part number checking I did a while back.
Comparing parts books, the only difference between CB160 and CD175 sloper cranks is the big end needle retainer and the inner flywheels otherwise all ---216-- part numbers.
Does anyone have a parts book scan of the vertical CD175 model please?
I have scans of CB160, early CD175/CL/CB175 ... I know CMS have them online but prefer the proper parts book.
https://www.dropbox.com/s/5k0tcbyen...5_Parts_Manual_Catalog_Download_1967.pdf?dl=0
https://www.dropbox.com/s/4e82cxmbsjv1wwk/CA175 parts list.pdf?dl=0
https://www.dropbox.com/s/fgfvgmg4evyd6h8/CB160 Part Index.pdf?dl=0
