Does anyone know if an upright --302-- crank will work in CD175A sloper please? I know the primary gear splines may be different but I assume that if you use the later gears it would be OK.
Well,....... I'm using a (CB) vertical crankshaft assembly in (CL) sloper cases for the land-speed record attempt bike......
They all seem to use the same bearings (the only actual interface with the cases) so I'd say YES......
Does that answer your question?.......
