Cylinders have been installed. The bike has been assembled and test run. The noise remains!
As a troubleshooting method I removed the primary gear and ran the engine (for a few seconds only because the oil pump runs off the clutch basket, which is driven by the primary gear.) The noise remains!
Removing the primary drive gear completely isolated the oil pump, primary drive, clutch basket, and all transmission gears and bearings. Earlier in the project I removed the sprag clutch and starter chain and retested as well.
With those items isolated, below is a list of things that it COULD possibly be.
- Crank main bearings
- Big end bearings
- Pistons
- Small end bearings
- Cam chain
- Cam chain tensioner
- Cam bearings
- Tappets
That's it! Now a list of why all of those things are unlikely.
- I replaced the two outer main bearings. The inner two felt fine. Plus, it just doesn't sound like bearing noise.
- Big end bearings
- I had the engine apart a few times, and they felt fine. Doesn't sound like big end noise really.
- Pistons
- I swapped pistons and cylinders, the noise remained.
- I swapped pistons, and the noise remained.
- Cam chain
- Cam bearings
- No damage. Plus, this head/cylinder was used in my CD175, and it didn't make any noise then.
- Tappets
When looking at parts lists, I found that for the CB200, some people are selling a 219T cam chain in 88 links, some with 86 links. CMSNL doesn't have any model year breaks for this. I can't verify how many links the chain I installed has. Is it possible that for some reason the cam chain is too tight? It would have been hard to install, and it wasn't. I DID notice however when assembling the engine that after assembling the top end and releasing the cam tensioner that it didn't move at all. Is the cam chain tensioner at the end of it's adjustment? Is the chain too tight somehow? Also, there is a difference between the CD175 and CB200 cam covers. Is the chain rubbing on the cover and I didn't notice?
I have ordered a new cam chain, 100 links, and I will cut to size and install a master link. I have ordered a CB200 cam cover. Next week I will pull the motor, replace the chain without splitting the cases, replace the cam cover, reinstall and test.
If that doesn't work I will replace the crank.
If that doesn't work I have no idea what to do.
