Thank Rod. So if I want to switch to 12 volt all I need is a rectifier/regulator, 12 volt flasher, 12 volt starter solenoid, and 12 volt bulbs?
While on paper the cd175 coil should just put out enough v /amp to charge a 12v battery ( the rec and reg are what really decided output voltage) in reality most people who have done this conversion ( myself included) can't get enough out of the cd stator to keep up with the battery losses.
There are no visual marking to differentiate between the cd and cb/cl stators, the winding may have a different gauge or number of turns ( you'd need to break a couple of stators down to check)
The plugs on all 175 twin's stators are all the same so no help with differentiating parts there unless you put a cb200 stator in ( it has a different neutral switch wich is soldered in)
You can fit any stator up to a cb360 into cd175 cases( but after the cb200 you need to drill out the Mount holes and add threaded inserts into 3 of the 6 and add your own timing maker)
You don't really need to update the starter solenoid as it's on for such a short amount of time it shouldn't burn out
Same for the 6v starter motor.
But you forgot to add 12v coil to you list of parts
