I picked up a 67 cd175 last year. The engine was moderately taken apart. I got it all back together and had it running a little for a few mins. Finally checked the compression and it was very low so I had the head rebuilt and put on new rings and just got it back together again. I also replaced the coil and the other thing that's in the frame near the coil (that I can't think of the name right now) now my questions: when I go to set the timing the test light never goes out, what did I connect incorrectly. And, I cannot get my neutral light to come on. I checked the connection at the switch in the engine and in the headlight house. And, part 2 of that question: when I operate the clutch lever and it moves the adjuster mechanism, should the shaft that the adjuster sits on also move. If not what operates the clutch to allow shifting?
Thank you all for being out there.
