Provided that both bikes have the same engine format ie sloper or upright, yes, the engine mounting points are the same.
You'd need to fit the CB air filters, and sort out the electrics for the CB starter, also convert from 6v to 12v, as the case may be.
CD exhausts should be OK.
Throttle grip is different, not sure if that makes a difference.
Great. Thanks for all the information. I want to upgrade the CD 175 electrical to 12volt and this CB175 is probably a cheaper alternative.
