Hi.
Upon reassembly of my engine, I feel as though my timing advancer springs may be worn excessively. Reason, when holding the end of the cam (at points plate), I can move the cam a couple degrees (2-3) without any spring return little effort applied). IS THIS TYPICAL? There is spring return, but only after the “play area”.
I can obtain the correct springs 14329-268-320...If I do this, can I replace (carefully) without removing sprocket from the head?
Reading online, it sounds like this is a very weak point. Is it better to go with an electronic advance altogether?
