Where is the Voltage regulator located on a CB500T?
What is the electrical component mounted on the right air box? I'm wondering if this is the voltage regulator, but the drawings show it with 3 wires and this thing only has 2 contacts.
I believe the third wire the ground is through the case..
The regulator DOES have three wires,(yellow, black, and green) and can NOT be case grounded.....The two prong module is the signal flasher............
