Tore down my CB500T to address some oil leaks, and to investigate why my I could never fit a feeler gauge between my right exhaust cam and rocker. Well I guess I've found the ugly truth. For some reason one of the two PO's replaced the right exhaust valve with a different, taller valve for who knows why. This in my mind explains why I never had clearance for a feeling guage [taller valve] and why the damn thing never ran right. An always open exhaust valve sounds like it would do it.
So I'm using this post to ask a few questions, I'm thinking of buying a used exhaust valve on fleabay and getting a machine shop to lap all of my valves. Ok to just replace the one bad valve? First time tearing an engine down...
Secondly how the hell do I remove the valve stem seals? I've tried to grab at them with pliers but they keep slipping off the metal ring imbedded within the seal, any trick to remove them?
Finally does my hypothesis sound right? Would a too tall exhaust valve cause a bad idle and running condition and cause white smoke to be burnt when running?
Below are the pictures of the removed valves and an example picture of the stem seal I cant remove. Thanks!
