I finally attempted a valve adjustment on my 76' CB500T, as the valves have been pretty noisy ever since I bought it.
Following the shop manual, I rotated the generator counter clockwise until the LT mark aligned with the index mark. Then because I thought the mark on the camshaft aligned with the mark on the bearing holder, I rotated another 360 degrees and set about adjusting the left side intake and exhaust valves. I set them to .0015" (rather than .0012") per some comments I saw on this site.
I spun the generator counterclockwise another 180 degrees (to the T mark), set the right side, and then put everything back together hoping for the best. The results were not good. Right side wasn't even firing and left side sounded terrible.
So after further reading on this site, I decided what I thought might have been the mark on the camshaft (which indicated to me that I needed to rotate the generator 360 degrees to get to TDC on the left side compression stroke) was not actually the correct mark (I can't seem to find a picture anywhere of what that mark looks like).
Following some further tips I read on this site, I put my finger over the left side spark plug hole when turning the generator. I felt a much greater push when approaching the LT mark one full turn (360 degrees) from where I had originally set the valves. Further, the lobes on the camshaft were now pointed away from the cam follower (before they had been pointed towards the follower on the side I was adjusting).
So in this new position, I set forth to re-adjust the clearances. Unfortunately, in this position I cannot get the clearances nearly small enough. The smallest I can get them is about .30 mm (10 times greater than the recommended .03mm). The same is true when I rotate to the T position and try the right side.
So, a couple of questions:
1. Did I have the pistons in the correct position the first or second time?
2. If I had the pistons in the correct position the second time, why can't I get the clearances small enough?
3. Does anyone have a picture of what the mark on the camshaft (that indicates whether you're TDC in compression or exhaust) looks like?
4. Any additional advice moving forward?
