Ok, finally got the electrical sorted out for the most part, now I'm having a possible mechanical problem. When I hit the starter, it turns the crank 1 rotation, then I hear alot of chain clatter as the starter spins, but it doesn't continue to turn the crank. Is this normal behavior, or is something wrong with the starter system?
Thanks!
Edit - Never mind, it's the starter clutch. Now I just need to get the flywheel off so I can find out which parts need replaced.
Thanks!
