Hi
im looking at doing a front end swap on my 500t to a gsxr usd forks and im swapping out the rear tyre to match as close as I can because the gsxr is far too wide at 180-190 and 5.5 inch rim so im looking at putting in an SV650 (which is a 4.5" rim and 160 tyre)
my question is does anyone know what the diameter of the rear spindle/axle is on the cb500t? I think the sv came in 17mm and 20mm so dependent on what the 500t is will depend on which year sv wheel I need
I know I will also need to fix some sprocket alignment issues and spacers etc but that should all be doable.
