Hello chaps!
I just rebuilt a CB500T in the UK and everything seemed to be working fine untill I decided to test the charging system.
I'm reading 11.5VDC at the battery with the key off. When I start it , it reads 11.7V and when I rev it , it goes to 11.9V . If I turn the lights on, it drops to 11.5 (This is a European model, therefore I can turn the lights off) Ok, so it's charging but just a little bit.
There are no burnt wires/contacts. There is no terminal corrosion and all plugs are as good as new.
I've tested the stator for AC output and only got good readings on 2 of the 3 testing connections. I cant find anything specific about testing these charging systems and my knowledge here is very scarce, therefore I beg for help.
