1 - 1 of 1 Posts
I've been working on a CB500T and having a few issues.
Electric starter is crapped out...the starter clutch will not stay bolted to the rotor.
Had a lot of trouble adjusting the clutch other day before the first stime I took it out. Too tight. Finally got it adjusted to where it wouldn't stall the engine when you put it in gear but it was a very, very fine line...no margin for error.
Yesterday the kickstarter wasn't working because the clutch was slipping and the engine wouldn't turn over. Is it possible that I over-tightened the bolts on the clutch when I was reassembing it and this is why I'm having trouble with the adjustment?
1 - 1 of 1 Posts
