I’m looking for an 18” spoked rear rim to replace my stock 16”.
I don’t need a rear sprocket or drum brake assembly.
Thanks
Easiest way to go is a CB400T1 rear wheel, 1978/79 only. T2's were ComStar. That way it's a direct swap although it does run a smaller tire, 110/90/18 is max.
Other option would be to replace the rim using you hub. You'd want a WM4, 2.50", 36 hole rim and use the T1 spokes.
Thank you Jim, I have been striking out on locating ‘78-79 CB400 rims. I was going to ask about potential of buying a rim and threading it onto my hub, but was having trouble finding the specific rim dimensions too. It’s like you read my mind.
I’m really new to this, so right now the learning curve is steep (and daunting). Your assistance makes it possible to stay engaged.
