Interesting that the front springs are 2 pieces, I'd guess that one is stiffer than the other. Looks like CMSNL has 4 of each upper and lower. There is the option of switching to a single spring. If your springs match up with the specs in the FSM then they are still good, replacing them won't change anything. Honda did use light oil in the forks most of the time, your spec may read as ATF which is roughly 7-8W oil. You can switch to 10W or 15W fork oil which will slow the shock action giving a stiffer front end. In many cases the soft front end is attributable to low oil and very old oil, it's supposed to get changed on a regular basis, @2 year intervals for most riders.
